Harður diskur 1,5 TB er 1,36 TB ??
Var að versla harðann disk sem er 1,5 TB en er bara 1,36 TB bara að spá hvað 140 GB eru notuð í þar sem þetta er flakkari?????
hagur
- Póstar: 3153
Re: Harður diskur 1,5 TB er 1,36 TB ??
http://hardforum.com/showthread.php?t=1347640
Listi yfir algengar stærðir og hve stórir þeir eru acually:
The difference in capacities is due to two different methods for defining what exactly the prefixes mega, giga, tera mean. In the computer world, these prefixes have different meanings depending on what exactly you are talking about. Hard drive manufacturers report the size of hard drives using the decimal definition of these terms (10^6, 10^9, 10^12 resepctively), whereas operating systems and other software use the binary definition of these terms (2^20, 2^30, 2^40).
As you can calculate, these values are close, but not exactly the same. 10^6 is 1,000,000, but 2^20 is 1,048,576. Once we get to larger hard drive sizes, the difference really becomes noticeable.
One gigabyte in binary is 1,073,741,824 bytes (2^30), but in decimal it’s only 1,000,000,000 bytes (10^9), which is a difference of 73,741,824 bytes (~70MB). So, when we're talking about storage size in gigabytes a hard drive's capacity as reported by the OS will be about 7% less than what is advertised by the hard drive manufacturer.
40GB = 37GiB
80GB = 74GiB
100GB = 93GiB
120GB = 111GiB
160GB = 148GiB
200GB = 186GiB
250GB = 232GiB
300GB = 279GiB
320GB = 297GiB
400GB = 372GiB
500GB = 465GiB
750GB = 697GiB
1000GB = 930GiB
Velkomin í heim auglýsingabrellna.
Þessi 140GB eru ekki notuð í neitt, þau eru bara ekki til staðar.
http://compreviews.about.com/od/storage/a/ActualHDSizes.htm
Since consumers don't think in base 2 mathematics, manufacturers decided to rate most drive capacities based on the standard base 10 numbers we are all familiar with. Therefore, one Megabyte equals one million bytes while one Gigabyte equals one billion bytes. This isn't too much of a problem with fairly small numbers such as a Kilobyte, but each level of increase in the prefix also increased the total discrepancy of the actual space compared to the advertised space.
Here is a quick reference to show the amount that the actual values differ compared to the advertised for each common referenced value:
* Megabyte Difference = 48,576 Bytes
* Gigabyte Difference = 73,741,824 Bytes
* Terabyte Difference = 99,511,627,776 Bytes
Based on this, for each Gigabyte that a drive manufacturer claims, they are over reporting the amount of disk space by 73,741,824 Bytes or roughly 70.3 MB of disk space. So, if a manufacturer advertises an 80 GB (80 billion bytes) hard drive, the actual disk space is around 74.5 GB of space, roughly 7% less than what they advertise.
Atvinnunörd - Part of the 2%
Eiiki
- /dev/null
- Póstar: 1408
- Skráði sig: Þri 09. Nóv 2010 14:23
- Staðsetning: 1101101
emmibe skrifaði:Svoleis, þá fer ég nú bara í búðina og fæ 140 GB endurgreidd
AntiTrust
- Póstar: 6379
- Skráði sig: Þri 19. Ágú 2008 20:58
Ekki vera newb
Haha, þetta hefði nú þótt slatti af geymslumagni fyrir x árum. Keyptu þér úlpu og það vantar aðra ermina.
AntiTrust
- Póstar: 6379
emmibe skrifaði:Haha, þetta hefði nú þótt slatti af geymslumagni fyrir x árum. Keyptu þér úlpu og það vantar aðra ermina.
Fyrir nokkrum árum var þetta hlutfallslega minni munur þar sem diskarnir voru minni, og maður kippti sér ekkert upp við þetta. Ég er alveg sammála þér að þetta sé fáránleg markaðssetning, en þetta hefur alltaf* verið svona og maður er bara búinn að læra að lifa með þessu.
*held ég.
bara pæling, má þá auglýsia þennan disk sem 1,5 TB
Intel E5200 @ 2.5 GHz | Radeon HD 4850 | Corsair 2x2 GB RAM 1066 MHz | 480 W aflgjafi | Móðurborð Micro-Star P43 NEO | 500GB Samsung | Windows 7 / Ubuntu
Ruddaleg túpuskjátölva!
AntiTrust
- Póstar: 6379
zdndz skrifaði:bara pæling, má þá auglýsia þennan disk sem 1,5 TB
Já, þetta eru tvær mismunandi túlkanir á tölunum, ekki beint lygi.
- Bannaður
- Póstar: 5677
- Staðsetning: ;)
Pfft ég ætla þá að fara og fá 42MB af nettengingunni minni endurgreidda AMIRITE emmibe?
Modus ponens
Revenant
- Póstar: 1052
- Skráði sig: Fim 24. Jún 2004 12:36
Ef þú lest á diskinn þá stendur eitthvað í þessa veru:
Sjá t.d. nánar á þessu FAQ hjá Seagate
When referring to hard drive capacity, one gigabyte, or GB, equals one billion bytes. Your computer's operating system may use a different standard of measurement and report a lower capacity.
Manuallinn segir....
1MB 1,000,000 bytes /1 GB 1,000,000,000 bytes/1TB 1,000,000
000,000 á disknum stendur 1,5 TB og það var það sem ég keypti en fékk bara hluta af vörunni. 1 TB var ekki til á lager sem ég vildi kaupa. Ætla að spyrja Samsung sem er framleiðandi disksins en hehe...........
Glazier
- BMW
- Póstar: 2511
- Skráði sig: Fös 30. Jan 2009 22:20
- Staðsetning: Mosó
Áður en þú ferð í verslunina og gerir þig að fífli.. þá skaltu hringja í þá og spurja þá út í þetta.
Get allveg lofað þér því (eins og allir aðrir hér á spjallinu) að þetta er algjörlega eðlilegt.
- Bannaður
- Póstar: 5677
- Staðsetning: ;)
Ég held að þú verðir sko heldur betur shocked þegar að þú kemst að því hvernig internettengingar eru auglýstar.
Uppsafnað skulda þeir þér eflaust hundruðir þúsunda skv. þinni hugmynd um endurgreiðslur.
Í fúlustu alvöru samt: Tera er einfaldlega forskeyti og er 'trillion' á ensku, TB í decimal (10^12) eru þá 1 000 000 000 000 bitar
en TB í binary (2^40) (sem er 'tölvutungumálið') eru 1 099 511 627 776 bitar.
1000000000000/1099511627776 = 0,909
Þú færð því 90,9% af decimal tera í binary tera.
Modus ponens
í windows allavega er 1mb = 1024kb, 2mb = 2048kb
hvartaðu frekar í microsoft hahahahaha
CPU: Intel i9-14900KS
Skjákort: RTX 5090 Palit
Kæling: 2x360 custom loop
Skjár: asus pg32ucdm
vesley
- Póstar: 4266
- Staðsetning: við talvuna
nonesenze skrifaði:í windows allavega er 1mb = 1024kb, 2mb = 2048kb
Það er vegna þess að 1mb er í svokölluðu "binary" í Windows eins og allt annað á hörðum disk.
Eins og Gúru sagði frá hérna fyrir ofan.
beatmaster
- Póstar: 3101
Líttu frekar á það þannig að Windows er að ljúga að þér (hver ákveður annars hvort er "réttara" decimal eða binary útreikningur)
SIKk
- Geek
- Póstar: 870
- Skráði sig: Mið 25. Mar 2009 20:55
- Staðsetning: Hafnarfjarðarsveit
ég hló
KermitTheFrog
- Póstar: 4273
Diskar eru auglýstir í SI einingum (GiB), en það sem þú sérð í tölvunni þinni er í svoköluðum binary einingum (GB). Samkvæmt SI einingunum er 1GB = 1000MB en samkvæmt binary er 1GB = 1024MB.
Það er auðvitað ekki bannað að auglýsa þá í SI einingunum, en það er sölutrikk. Eða hvort þetta sé samkvæmt einhverjum stöðlum eða e-ð. Þetta eru alveg nokkuð góð summ af gagnamagni sem þú missir þegar þú ert kominn í svona stóra diska.
Eru makkarnir ekki búnir að breyta þessu hjá sér?
Farnir að nota KiB/MiB/GiB fyrir base2 tölur og KB/MB/GB fyrir base10 eins og SI segir til um?
- Póstar: 17206
- Staðsetning: Hérna
Ég er með iMac, og 1TB disk. Hann er reportaður sem 1TB eða 999GB
k0fuz
- vélbúnaðarpervert
- Póstar: 999
- Skráði sig: Sun 05. Jún 2005 20:06
- Staðsetning: RVK
Stýrikerfið þitt les hvert gigabyte sem 1024mb en diskurinn þinn segir að hvert gigabyte sé 1000mb.
ASRock Z790 Pro RS WiFi | Intel i5 13600K @ 5.1GHz | Noctua NH-D14 | Gainward GeForce RTX 3060Ti Ghost OC | 2x16GB G.Skill Ripjaws S5 5600MHz DDR5 | 240GB Corsair MP510 NVMe & 250GB Samsung 850 EVO SSD | 2TB & 3TB Seagate | BenQ Zowie 25" XL2546 240Hz | 650W Corsair RM650x PSU.
gardar
- Póstar: 3111
- Skráði sig: Mán 11. Ágú 2008 02:49
- Staðsetning: ::1
JReykdal skrifaði:Eru makkarnir ekki búnir að breyta þessu hjá sér?
Eitthvað verið talað um að ubuntu séu að innleiða þetta líka fljótlega.
bulldog
- Póstar: 3439
- Skráði sig: Fim 10. Júl 2008 18:33
- Staðsetning: 127.0.0.1
emmibe skrifaði:Var að versla harðann disk sem er 1,5 TB en er bara 1,36 TB bara að spá hvað 140 GB eru notuð í þar sem þetta er flakkari?????
Það fara alltaf 7 % í partition töfluna þannig að 1.5 tb diskur verður 1,36 tb þegar inn í stýrikerfið er komið.
