Lyklaborð.. 1,599.99$
Black
Póstar: 2426
Pósturaf Black » Þri 23. Feb 2010 23:47
http://www.thinkgeek.com/computing/keyboards-mice/9836/
Ekki slæmt að eiga eitt svona Optimus Maximus..
Yep. Time to take a second mortgage on your home or break into your kid's college fund. With the singing of angels and a ray of sunlight parting the clouds, the fabled Optimus Maximus Keyboard has descended from Russian design studio Art Lebedev like an orgasm of geekiness. As you should know by now this amazing keyboard features a tiny screen on each key... that's 113 screens in all. What can you do with these tiny screens, you ask? Well, each key can change its image dynamically depending on what you're doing.Hold down SHIFT and all keys go uppercase. Run Photoshop and you can set it so each hotkey has an image representing its function. Set a key to monitor your CPU usage or display what iTunes track you are currently playing. You can make a key into a tiny clock with moving hands and play animated gif files or even quicktime movies. Of course all this futuristic technology is going to cost you a pretty penny... but we figure you'll just expense the Optimus and tout its "incredible increased efficiency when using PowerPoint hotkeys" in your expense report summary
Product Features
Revolutionary Keyboard Features a tiny OLED screen on each key. 113 screens total.
Each key can be individually programmed to perform a series of functions, open an application or run an Applescript (Mac only)
Various System Monitor functions can dynamically display on a key including CPU usage, CPU temperature, Network Speed, and Memory Usage
Play a GIF animation or Quicktime movie on a Key
Paint images across all keys at once in your image editor of choice
Key sets can be linked to an application, so whenever you open that app the appropriate keys come up
Powerful layer function allows you to combine existing key sets in different ways
Use any language with the appropriate key images including Cyrillic, Ancient Greek, Georgian, Arabic, Quenya, and Hiragana.
Display notes, numerals, special symbols, HTML codes, math functions or any other special symbol.
Any key (or to be exact, a unit consisting of a cap, a microchip and a display) can be easily removed by hands to be cleaned or replaced
Built in USB hub
SD Card Slot for Storing keyboard Settings
System Requirements
PC with installed OS Windows XP or Vista, with a USB 1.1 (or better 2.0) port; Mac OS X 10.5.1 or higher.
At least 20 MB of free space on hard drive.
At least 256 MB of RAM.
Product Specifications
Keyboard Dimensions: Length 537 mm, Width 173 mm, Height 38 mm
Key Dimensions: 20.2 x 20.2 mm
Display Dimensions: 10.1 x 10.1 mm viewable area on each key
Display Resolution: 48 x 48 pixels per key
Frame Rate: 10 FPS
Color Depth: 65,536 Colors
Viewing Angle: 160 degrees
http://www.youtube.com/watch?v=xWkjtnd367Q
Hverning fynnst ykkur svona gripur ! einhvað 200þ króna virði ? eða á maður bara halda sig við gamla lykalborðið :shock:
mér fynnst þetta algjört Waste of money,, en samt Frekar Töff! og flott þróunn örugglega gaman að geta sett hvað sem er á takkana :D
Mæli einnig með síðunni http://www.thinkgeek.com/ Hellingur af töff dóti þar til sölu :D :!:
Sydney
Póstar: 1108
Re: Lyklaborð.. 1,599.99$
Pósturaf Sydney » Þri 23. Feb 2010 23:49
Ef þú skítur peningum er þetta auðvitað svít.
Thinkpad X1 Yoga 2nd Gen OLED
svennnis
Póstar: 283
Skráði sig: Þri 05. Jan 2010 20:14
Staðsetning: á sporbraut sólar
Pósturaf svennnis » Þri 23. Feb 2010 23:52
true true ....
Antec P180EU |OCZ 700w| AMD 955 X4 3.2Ghz | XFX 5970 | Gigabyte 790FXTA-UD5 | GeIL Black Dragon DDR3 4x2=8GB | Tacens Gelus III Pro | SSD 128 GB | 500GB | 1000GB | 350GB |
