Til sölu Presonus Eris 5 XT Studio speakers, keyptir í hljóðfærahúsinu, í ábyrgð, mánaðargamlir.
https://www.hljodfaerahusid.is/is/vefve ... s-5-xt-par
Technical Specifications
Inputs
1- Balanced XLR
1- Balanced ¼” TRS
1- Unbalanced RCA
Performance
Frequency Response 48 Hz - 20 kHz
Crossover Frequency 3 kHz
LF Amplifier Power 45W
HF Amplifier Power 35W
Peak SPL (@ 1 meter) 102 dB
LF Driver 5.25”
HF Driver 1” silk dome
Input Impedance 10 kΩ
Dispersion 100 degrees horizontal by 60 degrees vertical
User Controls
Volume Range A-type taper
MF Control -6, 0, +6 dB
HF Control -6, 0, +6 dB
Low Cut Flat, 80 Hz, or 100 Hz
Acoustic Space Flat, -2 dB, or -4 dB
Protection
RF interference
Output-current limiting
Over-temperature
Turn-on/off transient
Subsonic filter
External mains fuse
Power
100-120V ~50/60 Hz or 220-240V ~50/60 Hz
Cabinet
Vinyl-laminated, medium-density fiberboard
Physical
Width 8” (203.2 mm)
Depth 9” (228.6 mm)
Height 11” (279.4 mm)
Weight 11 lbs (4.99 kg)
Verðhugmynd: 38þ
áhugasamir hafi samband
Til sölu Presonus Eris 5 XT Studio Active speakers *SELDIR**
Höfundur - Stjórnandi
- Póstar: 1323
- Skráði sig: Sun 22. Des 2002 00:14
- Staðsetning: MHz=MHz+1
Síðast breytt af Fletch á Fös 10. Sep 2021 18:23, breytt samtals 2 sinnum.
Síðast „Bumpað“ af Fletch á Mið 08. Sep 2021 13:45.
AMD Ryzen 5700X3D * Nvidia GTX 4080s * Asus TUF mATX * 64GB DDR4
Jensbo D31* Corsair PSU1000w * MSI 32" MPG 321URX 4k OLED
