---SELDIR--- Til sölu Jamo D4 heimabíósett
Farcry
Póstar: 406
Skráði sig: Mið 18. Apr 2012 16:38
Pósturaf Farcry » Lau 22. Apr 2017 20:02
Jamo D450
VERÐLÆKKUN 80.000
Hef til sölu flott Jamo hátalarasett , Búin að eiga þá í 10 ár hafa fengið mjög ástrikt uppheldi og líta vel út
Verðhugmynd 100.000
Upplýsingar í Ep eða Heidarxx(hja)gmail.com
Jamo D450 framhátalarar
Power, long/short term (Watt) 200/300
Sensitivity (dB - 2,8V / 1m) 89
Frequency range (Hz) 35 - 40k
Cross-over frequency (Hz) 2 k
Impedance (Ohm) 4
Jamo D4 Center Miðjuhátalari
System Type 2 Way Bassreflex
Impedance 4
Weight (Kg/lb) 6,8/14,99
Tweeter (mm/in) 25 DCD / 1
Woofer (mm/in) 2 x 114 / 4½
Inputs Gold plated screw terminals
Frequency Response (Hz, +/-3dB) 60 - 40.000
Power Handling (Watts Long/Short Term) 140 / 200
Sensitivity (dB, 2.8V/1m) 88
Jamo D4 Sub Bassabox
Impedance 22k
Weight (Kg/lb) 24,2/53,35
Woofer (mm/in) 2 x 203 / 8
Product dimensions (mm/in, HxWxD) 580x270x415/22,83x10,63x16,34
Rated output (W) 400 , 22 - 160
Jamo E700 bakhátalarar.
Impedance 6
Tweeter (mm/in) 1
Woofer (mm/in) 102 / 4
Frequency Response (Hz, +/-3dB) 70 - 20,000
Power Handling (Watts Long/Short Term) 100 / 140 , 85
Jamo D4
http://www.jamo.com/docs/jamo/support/w ... iption.pdf
http://www.hifi-review.com/151030-jamo-d4-sub.html
http://www.audioreview.com/cat/speakers ... 94crx.aspx
Síðast breytt af Farcry á Fim 06. Júl 2017 17:06, breytt samtals 1 sinni.
Farcry
Póstar: 406
Re: VERÐLÆKKUN Til sölu Jamo D4 heimabíósett
Pósturaf Farcry » Fim 15. Jún 2017 22:14
Farcry
Póstar: 406
Re: ---SELDIR--- Til sölu Jamo D4 heimabíósett
Pósturaf Farcry » Fim 06. Júl 2017 17:07
HÁTALARNIR ERU SELDIR
