[TS] CREE Led Vasaljós
Steini B
Póstar: 369
Skráði sig: Mið 02. Feb 2011 21:59
Staðsetning: í bjórbaði
Pósturaf Steini B » Mán 03. Okt 2011 01:04
Ertu hrædd/ur við mirkið?
Ef svo er þá er ég með til sölu eru þessi gífurlega öflugu vasaljós með um og yfir 1000 lumens*
Litla ljósið og höfuðljósið eru bæði ný og ónotuð, en stóra er lítið notað
Þau drífa öll vel yfir 350-400 metra **
UltraFire CREE XM-L T6 LED 1000Lm Vasaljós
Spekkar :
Output bright can come to above 1000 lumens [lm]
Model of LED: CREE XM-L T6 LED
Internal wiring applies the high efficient booster circuit, working voltage is wide and can utilize the batteries in the largest extent.
Waterproofing design
Aluminum alloy casing
Aluminum alloy reflector
5 switch Mode: high / middle / low / strobe / sos
Power by : 1 x 18650 3.7v
Colour : Black
Size(mm):135 x 30(bezel)/25(body)
Weight : 95g
Það sem fylgir:
100% Brand New
1 x UltraFire 501B CREE XM-L T6 LED Torch
1 x 18650 Rechargeable battery Charger (110-240v World voltage)
2 x 18650 3.7v 2400mAh Rechargeable Battery
http://myndasafn.bmwkraftur.is/d/95660-1/018.jpg
http://myndasafn.bmwkraftur.is/d/95662-1/017.jpg
Selt
CREE XM-L T6 LED 1000lm Hjólaljós / Höfuðljós
Can be used as Headlamp or Bicycie Light
Output bright can come to max 1000 lumens [lm]
3 switch Mode: Strong Brightness / Normal Brightness / Flashing
100v-240v Battery Charger ( LED indication for Power On / Charging / Full charge )
Model of Battery required: 1 x 8.4v 6400mAh Battery Pack
Dimension : 44mm
Weight : 130g
Það sem fylgir:
100% Brand New
1 x CREE XM-L T6 LED Light unit ( Can be used as Headlamp or Bicycie Light )
1 x Adjustable headband
2 x Rubber ring for installation
1 x Charger (100v-240v)
Verð: 10.000kr.
FlashMax X950 - CREE Q5 LED 1200 Lm Vasaljós
Þetta vasaljós er notað, en lýtur næstum út eins og nýtt.
CREE LED Emitter Type: Q5 (x5)
Lumens: 1200
LED Rated Life: 100,000 hours
Body Color: Black
Form Factor: Handheld torch style with tail click power button and knurled grip
Lighting Functions: - Low - Medium - High - Strobe (fast flash - Beacon S.O.S. (slow flash)
Power Source: 2 x 18650 type rechargeable battery (included)
Dimensions: 210 mm Long x 57 mm diameter
Waterproof to IPX-6 standard
Það sem fylgir með
Notað CREE LED Flashlight (Flashmax X950)
Notuð 2 x 18650 Rechargeable Battery (búið að endurhlaða 2x)
Battery Charger 100–240V
Verð: 7.000kr.
Hafið samband í PM
*samkvæmt framleiðanda
**Miðað við reglustrikuna á já.is
