Skipta um móðurborð og gera refresh windows 10, ekki reinstall?
Aimar
Póstar: 1421
Skráði sig: Mið 01. Sep 2004 09:43
Staðsetning: 201
Pósturaf Aimar » Fös 01. Júl 2022 08:23
Sælir.
Ég er að setja upp nýtt móðurborð. Úr Intel i AMD.
Hafa menn gert "Refresh Windows"
When you Refresh Windows, all apps that do not come with the standard Windows 1o installation, including installed programs, OEM drivers & pre-installed software, will be removed. You may also lose your digital licenses and other digital entitlements. You will have to install your apps and reactivate Windows again.
If your Windows 10 computer is facing a lot of issues including corrupt files, then it’s best to use Windows 10 Refresh Tool. The process does the following:
Keeps your personal files and settings
Replaces all Windows 11/10 system files with a new copy.
Keeps the apps that came with your PC
Keep the apps you installed from the Microsoft Store.
It ultimately fixes your computer without you worrying about any data loss.
Use it in case you are facing a lot of issues and corruption of system files. To use it, you need to download the Refresh Windows Tool from Microsoft.
GPU: AMD Radeon™ RX 7900 XT - GA z590 gaming X - Intel Core i7 11700k - Corsair Rm750x - Noctua-U12S - iCUE 465X RGB Mid-Tower- AORUS RGB Memory DDR4 16GB x4 3733MHz - Samsung 970 EVO 1TB M.2 2280 SSD - Win 10 Pro 64bit - ASUS ROG Swift Curved PG348Q @ 100mhz
Dr3dinn
Póstar: 621
Skráði sig: Mán 13. Ágú 2007 21:44
Re: Skipta um móðurborð og gera refresh windows 10, ekki reinstall?
Pósturaf Dr3dinn » Fös 01. Júl 2022 08:31
Hef notað refresh oftar en einu sinni, þetta svínvirkar. Sum settnings klilkkuðu en það var takmarkað. (eldri hugb)
Vélar
brain
Póstar: 1057
Pósturaf brain » Fös 01. Júl 2022 08:51
https://www.howtogeek.com/444351/how-to ... re-change/
hefur virkað fyrir mig. notað á Win 10 allavega 4 x á mismunandi vélum. Bæði laptop og desk
Aimar
Póstar: 1421
Staðsetning: 201
Pósturaf Aimar » Fös 01. Júl 2022 15:07
brain skrifaði:https://www.howtogeek.com/444351/how-to-reactivate-windows-10-after-a-hardware-change/
takk fyrir þetta. Ég er að leitast eftir að geta notað uppsett windows áfram. Leiðindin við að setja upp alla leiki, forrit og annað er smá að kvelja mig.
