SELT: Philips 43" 4K HDR1000 Skjár.
Zensi
Póstar: 37
Skráði sig: Mán 10. Apr 2023 00:22
Pósturaf Zensi » Mið 22. Maí 2024 18:14
Til sölu: Philips 43" "Momentum" 4K HDR display with Ambiglow #436M6VBPAB/00
Get in the moment
Experience a new level of entertainment immersion with the new Momentum 4K HDR display with Ambiglow lighting. An expansive 4K UHD display with DisplayHDR 1000 delivers ultra-crisp and vibrant image quality that will get you in the moment.
These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
Tengi: HDMI 2.0 x 2, DisplayPort 1.4 x 1, mini DisplayPort 1.4 x 1, USB-C (DP Alt mode), USB 3.0x2 (2 w/fast charging)*
Sync Input: Separate Sync, Sync on Green
Audio (In/Out): PC audio-in, Headphone out
Picture/Display: Panel Size 42.51 inch/108 cm
Aspect ratio: 16:9
LCD panel type: MVA
Backlight type: B-LED+QD Film
Pixel pitch: 0.245 x 0.245 mm
Optimum resolution: 3840 x 2160 @ 60 Hz
Brightness: 720 cd/m² (typical), 1000 cd/m² (peak) nit
Display colours: 1.07 billion colours (10 bit*)
Colour gamut (typical): NTSC 119%*, sRGB 145%*
Colour gamut (min.): BT. 709 Coverage: 100%*; DCI-P3 Coverage: 97.6%*
Contrast ratio (typical): 4000:1
SmartContrast: 50,000,000:1
Response time (typical): 4 ms (Grey to Grey)*
Viewing angle: 178º (H)/178º (V) @ C/R > 10
Picture enhancement: SmartImage
Effective viewing area: 941.18 (H) x 529.42 (V)
Scanning Frequency: 23 - 80 Hz (V)/30 - 160 kHz (H)
sRGB: Yes
Flicker-free: Yes
Pixel Density: 103.64 PPI
LowBlue Mode: Yes
Display Screen Coating: Anti-Glare, 3H, Haze 2%
Low Input Lag: best time < 4 ms
Adaptive sync: Yes
HDR: DisplayHDR 1000 and UHDA certified
Built-in Speakers: 7 W x 2 with DTS sound
Plug and Play Compatibility: DDC/CI, Mac OS X, sRGB
Other convenience: Ambiglow, Low Input Lag, Kensington lock, VESA mount (200 x 200 mm)
MultiView: PIP/PBP mode 2 x devices
Stand: Tilt -5/10 degree
SELT
Síðast breytt af Zensi á Fim 30. Maí 2024 22:14, breytt samtals 2 sinnum.
Zensi
Póstar: 37
Re: TS: Philips 43" 4K HDR1000 Skjár. Lækkun 50.000
Pósturaf Zensi » Þri 28. Maí 2024 13:51
Lækkað verð, 50.000 kr
traustitj
Póstar: 98
Skráði sig: Lau 31. Júl 2021 23:49
Pósturaf traustitj » Fim 30. Maí 2024 20:46
Átt skilaboð
