Hi.
I need to upgrade old cpu.
Currently have 7700k.
Budget: around 30k.
CPU Upgrade needed.
Harold And Kumar
- Tölvutryllir
- Póstar: 631
- Skráði sig: Lau 21. Sep 2019 22:53
Re: CPU Upgrade needed.
Not much of an upgrade path from a 7700k on the same platform, if any. If I were you I’d sell the cpu, motherboard & ram as a combo then buy a better cpu motherbord and ram
Ryzen 7 7800X3d
RTX 3080 10Gb
32gb ddr5 6000MTS
1440p 180hz
RTX 3080 10Gb
32gb ddr5 6000MTS
1440p 180hz
Harold And Kumar skrifaði:Not much of an upgrade path from a 7700k on the same platform, if any. If I were you I’d sell the cpu, motherboard & ram as a combo then buy a better cpu motherbord and ram
Yes, I agree, it would be wiser to do. But I am on a tight low budget, and am using this pc for work, so I cant stay without pc.
Thought I could get some cpu with or without motherboard, and replace it.
What are you going to upgrade to? isnt this the highest specced CPU for this chipset?
olihar skrifaði:What are you going to upgrade to? isnt this the highest specced CPU for this chipset?
Based on Google search, socket 1151, supports any cpu from 6700k-9900k.
Next I would need to change motherboard and RAM accordingly, but at this moment CPU is issue for me.
And how are you going to upgrade to anything better?
https://www.asus.com/uk/supportonly/z17 ... pdesk_cpu/
TheAdder
- vélbúnaðarpervert
- Póstar: 946
NotMe skrifaði:olihar skrifaði:What are you going to upgrade to? isnt this the highest specced CPU for this chipset?
The socket does, but the chipsets don't, 6000 and 7000 series cpu's are supported by the same chipsets, 8000 and 9000 are supported by other chipsets.
The z170 chipset only supports up to 7700K.
TheAdder skrifaði:NotMe skrifaði:olihar skrifaði:What are you going to upgrade to? isnt this the highest specced CPU for this chipset?
Aaah then, I need to do CPU+MB anyway,
thanks for checking and letting me know. Very much appreciated.
