PDU NETBOOTER™ NPB-20DU(H)
Arithor
Póstar: 13
Skráði sig: Þri 21. Sep 2010 18:57
Pósturaf Arithor » Fös 17. Maí 2024 22:51
Er með NETBOOTER™ NPB-20DU(H) til sölu ATH þetta er (H)
Lítið eða ekkert notað
1 inn 20 út
Óska eftir tilboði
skipti möguleg
Meira tekið af netinu
Features:
20 Independently managed power outlets.
True RMS current sensor provides total amperage across all outlets.
Configure and control with HTTP/HTTPS web interface or command line via Telnet / Serial
Supports TLS V1.2 encryption for HTTPS access
Source IP Address Access Filtering/Blocking
Use Autoping to reboot outlets after specified ping losses.
Daily reboot or weekly schedule for outlet on/off time.
Sync to NTP server or use real-time clock.
Sends event notifications via email or view local event log.
Restrict users to individual outlets as desired.
Use external dial-up modem for backend solution (DB9 serial port)
Specifications: (Note - Applies to H version)
20 x NEMA 5-15R Outlets - (20 x IEC 320 C13 Outlets)
Handles up to 30A at 120VAC - 20A at 230VAC (H Nodel)
0U enclosure: L 53.24" x W 2.8" x H 1.75"
1 x DB9 RS232 Port: Data: 7 or 8 bits. Stop Bits: 1 or 2. Parity: None Flow Control: None. Baud Rate: 2400 to 19200.
Network Protocols: HTTP/HTTPS, IP/TCP, ICMP, NTP, SMTP, POP3, DHCP, Telnet, and BootP
Network Interface: 10/100-Base T. RJ-45.
Operational Temperature Environment: -25C° → 50C°
Humidity: 5-95%, non-condensing
Safety and Compliance: cTUV(US & Canada), UL-60950, FCC Class B
Running1
Póstar: 116
Skráði sig: Þri 10. Okt 2017 17:44
Re: PDU NETBOOTER™ NPB-20DU(H)
Pósturaf Running1 » Lau 18. Maí 2024 20:52
A thing of Beauty
