Til sölu ASUS router / netbeinir, ASUS RT-AXE7800 Wireless Tri-Band 2.5G / 1G Router *SELDUR*
Fletch
Póstar: 1328
Staðsetning: MHz=MHz+1
Pósturaf Fletch » Fös 22. Des 2023 09:43
Til sölu geggjaður ASUS router / netbeinir, ASUS RT-AXE7800 AXE7800 Wireless Tri-Band 2.5G / 1G Router
Key Specs
Wi-Fi
Wi-Fi 6 (802.11ax); Tri-Band (2.4, 5, & 6 GHz) with MU-MIMO Support (4 x 4)
Throughput
7780 Mb/s Total
6 GHz: 2402 Mb/s
5 GHz: 4804 Mb/s
2.4 GHz: 574 Mb/s
Show More
Inputs/Outputs
1 x 2.5 Gb/s Ethernet (RJ45) (Uplink)
1 x 10/100/1000 Mb/s Gigabit Ethernet (RJ45) (Uplink)
3 x 10/100/1000 Mb/s Gigabit Ethernet (RJ45)
1 x 5 Gb/s USB-A
Show Less
Wireless
Wi-Fi
Number of Antennas
6
Supported Protocols
DHCP Server
IPv6
Link Aggregation
MAC Filtering
RADIUS
Antenna Placement
External (Integrated)
Cellular Support
No
Performance
Throughput
7780 Mb/s Total
6 GHz: 2402 Mb/s
5 GHz: 4804 Mb/s
2.4 GHz: 574 Mb/s
Interface
Inputs/Outputs
1 x 5 Gb/s USB-A
USB Sharing Support
Yes
Security
Guest Network Support
Yes
Wireless Security
WPA-PSK, WPA-Enterprise, WPA2-PSK, WPA2-Enterprise, WPA3-PSK, WPS
VPN Protocol
IPSec, L2TP, PPTP, Pass-Through
Firewall Support
NAT
Lock Slot
No
Mobile App Compatible
Yes: Android & iOS
App Name: ASUS Router
Functionality: Adjust Settings, Setup
*As of November, 2022: Check with manufacturer for the most up-to-date compatibility
Hardware
RAM
512 MB
Storage Capacity
256 MB
CPU
Quad-Core: Up to 1.7 GHz
Supported IEEE Standards
802.11a, 802.11ac, 802.11ax, 802.11b, 802.11g, 802.11n
Electrical
AC Input Power
110 to 240 VAC, 50 / 60 Hz
General
Environmental Protection
No
Weight
2.3 lb / 1033 g
Packaging Info
Package Weight
3.78 lb
Box Dimensions (LxWxH)
10.4 x 10.4 x 4.4"
Verðhugmynd 32þ
áhugasamir hafi samband
Síðast breytt af Fletch á Sun 03. Mar 2024 16:13, breytt samtals 3 sinnum.
MariusThor
Póstar: 25
Skráði sig: Þri 30. Des 2008 02:09
Re: Til sölu ASUS router / netbeinir, ASUS RT-AXE7800 Wireless Tri-Band 2.5G / 1G Router
Pósturaf MariusThor » Sun 03. Mar 2024 13:48
Enn til?
Fletch
Póstar: 1328
Re: Til sölu ASUS router / netbeinir, ASUS RT-AXE7800 Wireless Tri-Band 2.5G / 1G Router *SELDUR*
Pósturaf Fletch » Sun 03. Mar 2024 16:25
seldur
