[TS] Vantec Nexstar-3 External HD Enclosure with eSata & USB 2.0
Cashier
Póstar: 100
Skráði sig: Mið 04. Ágú 2010 12:19
Pósturaf Cashier » Lau 25. Nóv 2023 18:58
Álhýsing og 1TB HDD, allir kaplar fylgja.
Verð: Tilboð
Verðhugmynd: 7þús
https://www.coolerguys.com/products/vantec-nexstar-3-external-hd-enclosure-with-esata-usb-2-0-nst-360su-bk
Form and functionality collide with style in the NexStar 3 External SATA Hard Drive Enclosure from Vantec. With its mirror finish, sleek curves and bold colors, the Vantec NexStar 3 stands out from the crowd. The sturdy drive cage protects your hard drive while the aluminum case effectively draws away the heat, protecting your drive from overheating. The NexStar 3 features eSATA (external Serial ATA) and USB 2.0 interfaces offering speeds up to 3Gbps or 480Mbps respectively. This flexibility allows you to use your hard drive at its full performance where eSATA is available and still have the option of using USB where it's not. The NexStar 3 is an ideal way to store and transfer large amounts of data in an enclosure that matches your style!
Cashier
Póstar: 100
Re: [TS] Vantec Nexstar-3 External HD Enclosure with eSata & USB 2.0
Pósturaf Cashier » Sun 17. Des 2023 11:05
Lækkað verð - 5þús!
