[TS] Dell 27 g-sync 144hz 1440p
baron
Póstar: 4
Skráði sig: Lau 23. Apr 2022 22:19
Pósturaf baron » Sun 24. Apr 2022 22:48
27 tommu 1440p 144hz g-sync skjár. Keyptur í Advania fyrir 3 árum á 99.990.kr.
Verð 49.000kr eða best boð
Dell S2716DG
Display
Diagonal Viewing Size
68.5 cm
27 Inches (27-inch wide viewable image size)
Panel Type, Surface
TN , Anti-Glare with 3H hardness
Optimal Resolution
2560 x 1440 at 144Hz
Preset Display
Area (H x V)
596.74 mm x 335.66 mm
23.49 inches x 13.21 inches
Contrast Ratio
1000: 1 (typical)
Backlight Technology
LED
Brightness
350 cd/m² (typical)
Response Time
1 ms FAST Mode
Viewing Angle
160° vertical / 170° horizontal
Pixel Pitch
0.3114 mm x 0.1038 mm
Display Type
Widescreen Flat Panel Display
Device Type
Monitor
Color Support
Color Gamut (typical)2: 82% (CIE1976), 72% (CIE 1931)
16.7 Million colors
Aspect Ratio
Widescreen (16:9)
Flat Panel Mount Interface
VESA (100 mm)
Display Screen Coating
Audio Output
1 x Audio line-out, 1 x Headphone port
Adjustability
Tilt. Head Adjustable, Swivel, Pivot
Síðast breytt af baron á Mið 27. Apr 2022 09:32, breytt samtals 1 sinni.
