[ALLT SELT] WD 1tb NVME - CorsairRM1000x
Lexxinn
Póstar: 1457
Staðsetning: Júpíter
Pósturaf Lexxinn » Fim 09. Des 2021 22:21
Eingöngu beinar sölur, tek engin skipti til greina eins og stendur.
WD SN550 Blue 1tb (ónotaður, enn í kassanum og innsiglaður)
Verð: 19þ
Boost your system's performance with next-gen NVMe SSDs
Over 4 times faster than our SATA SSDs
Slimline M.2 2280 form factor
Western Digital-designed controller and firmware for optimized performance
Western Digital SSD Dashboard constantly monitors the health of your SSD
Max Sequential Read Up to 2400 MBps
Max Sequential Write Up to 1950 MBps
[mynd af minninu]
Corsair RM1000X 80 PLUS GOLD] (ónotað, enn í plastinu)
Verð: 32þ
Power:1000 Watts
Modular ATX 12V 2.4 / EPS 2.92 power supply
80PLUS Gold certified
Noise level: between 0 dB(up to 40%) and 23 dB(full load)
135 mm fan
Active power factor correction (PFC) with a value of 0.99 PF
MTBF: 100,000 hours
Protection against overvoltage, overcurrent, undervoltage, short circuit, overload and overheating
10 year manufacturer's warranty
[hér var mynd af eins aflgjafa]
Antec P183 - SELDUR
Verð: 4þ
[mynd af svona kassa]
Gigabyte 2080 Super Rev 2.0 - SELT
Verð: 110þ
Features
Powered by GeForce® RTX 2080 SUPER™
Integrated with 8GB GDDR6 256-bit memory interface
WINDFORCE 3X Cooling System with alternate spinning fans
RGB Fusion 2.0 – synchronize with other AORUS devices
Metal Back Plate
Core Clock
1815 MHz
[hér var mynd af skjákorti]
Kingston Fury Beast 32gb (2x16gb) 3600mhz - DDR4 (ónotað, ennþá innsiglað) - SELT
Verð: 24þ
[hér var mynd af minninu]
Ryzen 3600 - stock kæling fylgir - SELDUR
Verð: 20þ
Síðast breytt af Lexxinn á Mán 13. Des 2021 21:00, breytt samtals 22 sinnum.
Póstar: 6799
Re: [TS] Íhlutapartý - 2080Super - CorsairRM1000x - KingstonFury32gb3600mhz - Ryzen3600 - AntecP183
Pósturaf Viktor » Fös 10. Des 2021 07:29
Ég tek Ryzen :japsmile
Lexxinn
Póstar: 1457
Re: [TS] Íhlutapartý - CorsairRM1000x - AntecP183
Pósturaf Lexxinn » Fös 10. Des 2021 16:57
Bump og uppfærsla á original póst, lítið eftir af þessu íhlutapartýi - Corsair aflgjafinn og Antec kassinn enn til sölu!
Gætu bæst við 2x 1tb nvme WD diskar (óopnað, enn innsiglað) - ef eitthverjir hafa áhuga áður en ég set inn proper auglýsingu má senda mér pm fyrir þá.
einaroli
Póstar: 52
Skráði sig: Þri 19. Des 2017 12:43
Re: [TS] Íhlutapartý - CorsairRM1000x (ónotað) - AntecP183
Pósturaf einaroli » Lau 11. Des 2021 08:33
Sendu hvað þu ert til i að losna við aflgjafan á
Póstar: 6799
Pósturaf Viktor » Lau 11. Des 2021 08:46
Býð 2500 í Antec
Lexxinn
Póstar: 1457
Pósturaf Lexxinn » Lau 11. Des 2021 10:46
einaroli skrifaði:Sendu hvað þu ert til i að losna við aflgjafan á
Mér þykir ég frekar hóflegur í verðlagningu á enn innsigluðum aflgjafa, 20% af miðað við verð út úr TL
Sallarólegur skrifaði:Býð 2500 í Antec
3þ og hann er þinn
Póstar: 6799
Pósturaf Viktor » Sun 12. Des 2021 10:18
Lexxinn skrifaði:
3þ og hann er þinn
Til í það bjalla á eftir eða mrg
Lexxinn
Póstar: 1457
Re: [TS] WD 1tb NVME (ónótaður) - CorsairRM1000x (enn í plastinu)
Pósturaf Lexxinn » Mán 13. Des 2021 11:24
bump - psu og nvme saman á 45þ
Síðast breytt af Lexxinn á Mán 13. Des 2021 11:29, breytt samtals 1 sinni.
seanscongack28
Póstar: 90
Skráði sig: Mið 22. Apr 2020 15:40
Pósturaf seanscongack28 » Mán 13. Des 2021 11:37
pm
