Er með þennan frábæra skjá til sōlu, ips panel,Gsync og 165hz.
Verðhugmynd 55k
Hægt er að ná í mig í síma 861-7334
Specs:
Maximum Resolution
(WQHD)2560 x 1440@144 Hz
Aspect Ratio
16:9
Contrast Ratio
1,000:1
Response Time
4 ms GTG
Overclock Refresh Rate
165 Hz
Color Supported
16.7 Million
Adaptive Contrast Management (ACM)
100,000,000:1
Brightness
350 cd/m²
Backlight
LED
Viewing Angles
178° Horizontal
178° Vertical
Panel Type
IPS (In-plane Switching)
Stand
Tilt (-5°~35°)
Swivel (60°)
Height adj (5.91")
Speakers
2 x 2 W
Ports & Connectors
(1.2)
1x USB 3.0 Upstream
4x USB 3.0 Downstream
Power
32.02 W (Power On)
Environmental Certification
RoHS, MPR II, Energy Star Qualified
Tearing Prevention Technology
NVIDIA® G-SYNC®
VESA Compatible
100 x 100mm
Dimensions (W x H x D)
24.09" x 14.45" x 2.40"
Weight (Approximate)
12.8 lbs.
17.6 lbs. (with stand)
TS: acer predator xb271hu
Höfundur - Nörd
- Póstar: 130
- Skráði sig: Mið 12. Okt 2005 23:04
- Staðsetning: Reykjavik
Síðast breytt af tonycool9 á Sun 03. Okt 2021 14:30, breytt samtals 1 sinni.
