[TS] Macbook Pro 2018 15in Top Spec
toeknee
Póstar: 13
Skráði sig: Mið 20. Nóv 2019 14:32
Pósturaf toeknee » Lau 21. Des 2019 15:25
I'm selling this because I very rarely use it, and I hope it can go to someone who will use it properly! Thus it is a FANTASTIC condition because of how little it is used.
The specs are as follows:
15.4inch (39cm)
16GB RAM
512GB SSD
AMD Radeon 560x Graphics card (With Intel UHD 630 for low power switching)
Touchbar + TouchID
The OS is currently MacOS 10.14.6 so no need to downgrade if you run 32 bit apps.
Willing to negotiate on price, but only fielding serious offers.
Comes with original charging cable and brick, of course.
Screen Shot 2019-12-21 at 15.01.51.png (97.18 KiB) Skoðað 2482 sinnum
Screen Shot 2019-12-21 at 15.01.38.png (135.08 KiB) Skoðað 2482 sinnum
Screen Shot 2019-12-21 at 15.01.30.png (252.87 KiB) Skoðað 2482 sinnum
Viggosson
Póstar: 113
Skráði sig: Sun 07. Júl 2019 23:51
Re: [TS] Macbook Pro 2018 15in Top Spec
Pósturaf Viggosson » Lau 21. Des 2019 20:11
Are you interested in trade,pc + Monitor?
toeknee
Póstar: 13
Pósturaf toeknee » Lau 21. Des 2019 21:02
Viggosson skrifaði:Are you interested in trade,pc + Monitor?
I wish but I don't have room for a PC setup right now :(
Harold And Kumar
Póstar: 631
Pósturaf Harold And Kumar » Sun 22. Des 2019 16:57
this is not a top spec model btw. its only 512 gb ssd while the top spec model has much mire then that
Ryzen 7 7800X3d
RTX 3080 10Gb
32gb ddr5 6000MTS
1440p 180hz
toeknee
Póstar: 13
Pósturaf toeknee » Mán 23. Des 2019 10:25
Harold And Kumar skrifaði:this is not a top spec model btw. its only 512 gb ssd while the top spec model has much mire then that
This was the highest configuration that was readily produced - anything higher (1TB - 4TB) had to be ordered from Apple, as those configurations were manufactured to order :)
benony13
Póstar: 170
Skráði sig: Sun 11. Okt 2015 21:28
Pósturaf benony13 » Mán 23. Des 2019 10:49
Hvað er verðið?
toeknee
Póstar: 13
Pósturaf toeknee » Mán 23. Des 2019 13:22
benony13 skrifaði:Hvað er verðið?
pm
Harold And Kumar
Póstar: 631
Pósturaf Harold And Kumar » Mán 23. Des 2019 14:43
toeknee skrifaði:
Still not the TOP SPEC Model
Ryzen 7 7800X3d
RTX 3080 10Gb
32gb ddr5 6000MTS
1440p 180hz
toeknee
Póstar: 13
Pósturaf toeknee » Mán 23. Des 2019 14:51
toeknee skrifaði:
If you want to be semantic then I can argue that yes, it is "top spec", as the CPU and the GPU are fully upgraded for this model/year. And depending on your workflow, upgrading to 32GB ram wouldn't offer any benefit in terms of output :)
edit: regardless of semantics, the price does not change because I said "top spec". the price, if you're interested, is based off of sold items on eBay of the exact same configuration/year/color. hope this clears things up for you!
Harold And Kumar
Póstar: 631
Pósturaf Harold And Kumar » Þri 24. Des 2019 09:44
actually you have an i7 while the top spec model was an i9
Ryzen 7 7800X3d
RTX 3080 10Gb
32gb ddr5 6000MTS
1440p 180hz
toeknee
Póstar: 13
Pósturaf toeknee » Fös 27. Des 2019 10:51
Harold And Kumar skrifaði:actually you have an i7 while the top spec model was an i9
Which, 1. had to be made to order, rather than readily available and 2. thermal throttled under load thus having similar performance to the i7
bump and gleðileg jól ;)
Harold And Kumar
Póstar: 631
Pósturaf Harold And Kumar » Fös 27. Des 2019 11:03
samt ekki TOP SPEC BTW
Ryzen 7 7800X3d
RTX 3080 10Gb
32gb ddr5 6000MTS
1440p 180hz
Póstar: 17206
Pósturaf GuðjónR » Fös 27. Des 2019 11:59
Villandi auglýsing, tölvan er ekki Top-Spec og það hefði mátt taka fram að það er ekki Íslenskt lyklaborð.
Þræði læst.
