Fast verð 55k
Í toppstandi - Hef ekki tíma fyrir leiki næstu misserin.
Kostar 90k nýr
Sami skjár og allir pro CS spilarar nota á stóru mótunum!
http://zowie.benq.com/en/product/monitor/xl/xl2540.html
Display
LCD size (inch)
24.5
Aspect ratio
16 : 9
Max. resolution
1920 x 1080 at 240Hz (HDMI 2.0, DP)
Display area
543.744 x 302.616
Pixel pitch (mm)
0.28
Typ. brightness (cd/㎡)
400
Typ. contrast
1000 : 1
Typ. DCR (DyNamic Contrast Ratio)
12M : 1
Panel type
TN
Response time
1ms (GtG)
Connectivity
Input/Output connector
DVI- DL / HDMI x2 / DP1.2 / headphone jack / microphone jack
USB
Downstream x3 Upstream x1
Electricity
Power supply (90~264 AC)
Built- in
Power consumption (On mode)
55W
Size & Weight
Dimensions (HxWxD mm)
High: 515.43 x 569.94 x 226.04 Low: 445.75 x 569.94 x 226.04
Net weight (kg)
7.5
Gross weight (kg)
11.3
Stand
VESA wall mounting 100x100 mm
V
Pivot 90°
V
Swivel (left/right)
45/45
Tilt (°)
-5 ~ 20
Height adjustment (mm)
140
Special Features
Shield
V
S Switch
V (Profiles to go)
Black eQualizer
V
Color Vibrance
V
Low Blue Light
V
Flicker-free
V
K Locker
V
Variable Refresh Rate Technology compatible
V (G-SYNC compatible , FREESYNC)
selt selt selt: Benq 240hz G-Sync / Freesync skjár
Höfundur - Internetsérfræðingur
- Póstar: 6855
- BF948D82-4642-488F-B075-339AF1561D93.png (234.06 KiB) Skoðað 875 sinnum
kristjanfinns
- Nýliði
- Póstar: 12
- Skráði sig: Sun 16. Jún 2019 21:49
