TS Móðurborð, CPU og RAM [Selt]
valgeirthor
Póstar: 120
Skráði sig: Fim 10. Jan 2008 09:50
Pósturaf valgeirthor » Mán 13. Feb 2017 21:11
Er með þetta furðulega combo sem mig langar að selja.
SUPERMICRO MBD-X10SLL-F-O uATX Server Motherboard LGA 1150 DDR3 1600
https://www.newegg.com/Product/Product.aspx?Item=N82E16813182819
1. Single socket H3 (LGA 1150) supports Intel® Xeon® E3-1200 v3/v4, 4th gen. Core i3, Pentium, Celeron processors
2. Intel® C222 Express PCH
3. Up to 32GB DDR3 ECC 1600MHz UDIMMs in 4 sockets
4. Dual Gigabit Ethernet LAN ports (1x Intel® i217LM & 1x Intel® i210AT)
5. 2x SATA (6Gbps), 4x SATA (3Gbps)
6. 1x PCI-E 3.0 x8 (in x16), 1x PCI-E 3.0 x8, and 1x PCI-E 2.0 x4 (in x8) slots
7. 2x USB 3.0 (1 Type-A + 1 via header) 6x USB 2.0 (4 rear + 2 via header)
8. Integrated IPMI 2.0 with KVM and Dedicated LAN
9. SATA DOM power connector support
10. VGA D-sub connector, TPM header
Intel G3258 4 Pentium 3.20 GHz 3M Cache 2 Core Processor (BX80646G3258)
https://www.amazon.com/Intel-G3258-Pentium-Processor-BX80646G3258/dp/B00KPRWAZQ
Compatible with Intel 8 or 9 series Chipsets
LGA 1150
2 cores
3.2Ghz base frequency
Intel HD Graphics
Intel Quick Sync Video enabled
3MB Intel Smart Cache
2 Channel DDR3-1333 memory support
4x = 32GB Samsung 8GB PC3-12800 DDR3-1600MHz ECC Unbuffered CL11 240-Pin DIMM 1.35V Low Voltage Dual Rank Memory Module Mfr P/N M391B1G73QHO-YKO
http://www.memory4less.com/samsung-8gb-ddr3-pc12800-m391b1g73qho-yko
Manufacturer Samsung
Manufacturer Part # M391B1G73QHO-YKO
Memory Type DDR3 SDRAM
Capacity 8GB
Pins 240 Pin
Bus Type PC-12800
Error Correction ECC
Cycle Time 1.25ns
Cas CL11
Data Transfer Rate 1600Mhz
Memory Clock 200Mhz
Rank Rank 2
Voltage 1.35
Einnig stock intel kæling fyrir örgjörvann
Þetta er fínt sem lítill server ekki síst af því það er Integrated IPMI 2.0 with KVM and Dedicated LAN
Tilboð, samþykki fyrsta alvöru boðið, (hint 30k)
