[TS]GIGABYTE GE-R460-V1 Superb 460W PSU, aflgjafi.
Höfundur - Nýliði
- Póstar: 12
- Skráði sig: Þri 05. Apr 2016 18:07
GIGABYTE GE-R460-V1 Superb 460W PSU, Active PFC, high efficiency power circuit design, 12cm Silent Fan with Full ventilated rear plate, Over-voltage, over-current, under-voltage and short circuit protection, Connectors: 1x PCI-Express / 4x SATA / 4x IDE - No Power cord
Model GE-R460-V1
Dimension 150 x 140 x 86 mm
Weight 1.5 kg
Connectors
24-pin Motherboard Connector 1
4pin +12V CPU Connector 1
6 Pin PCI-E Connector 1
SATA Connectors 4
4-pin Peripheral Connectors 4
4-pin Floppy Connectors 2
Info
AC INPUT 200~240V~, 3A, 50Hz
TYPE ATX 12cm
PFC Active PFC
DC OUTPUT +3.3V +5V +12V1 +12V2 -12V +5Vsb
30A 30A 14A 15A 0.8A 2A
Max Combined Wattage 152W 348W 9.6W 10W
380.4W 19.6W
400W
Peak wattage 460W
Safety Approval CE, CB, TUV, C-Tick
tekið úr tölvu og notað, í góðu standi.
Verð = 3000kr
