[SELDUR] BenQ 24" LED
tanketom
Póstar: 1043
Skráði sig: Fim 06. Jan 2011 12:39
Pósturaf tanketom » Mið 02. Sep 2015 18:59
BenQ GL2450
Er með Þennan flotta 24" BenQ skjá, lítið notaður, Kemur í kassanum með öllu.
Hann er keyptur í tölvutek fyrir sirka hálfu ári.
Verð: SELDUR
BenQ GL2450: Specs
Visible screen diagonal (cm): 61.0
Panel technology: TN
Aspect ratio: 16:9
Screen finish: matt
Resolution (pixel): 1920 x 1080
Pixel density (ppi): 92
Measure checkerboard contrast ratio: 610
Measured maximum brightness (cd/m2): 261
sRGB gamut (%): 99
Adobe RGB gamut (%): 77
Colour accuracy avg (delta-E): 1.57
Stand Tilt: -5/15 degrees
Video Inputs: VGA, DVI-D
Connector orientation: vertical
USB: N
Speakers, amp: None
Audio inputs: None
Other features: internal PSU
Overall size (whd): 579 x 436 x 179
Power consumption max/120 cd/m^2 (watt): 21 / 12
Bezel type: Thick Bezel
Cable management: N
Button type: push-buttons
Rated response time: 2 ms GtG
Rated viewing angles H/V: 170 / 160
VESA mount: VESA 100
Weight: 4.1 kg
Síðast breytt af tanketom á Mið 02. Sep 2015 20:43, breytt samtals 1 sinni.
pwr
Póstar: 22
Skráði sig: Sun 19. Jan 2014 20:59
Re: [TS] BenQ 24" LED
Pósturaf pwr » Mið 02. Sep 2015 19:55
þú átt pm.
gtx1070fx8350h100i16gb990fx750w4x24.
