Selt, má eyða
goatboy
Póstar: 15
Skráði sig: Lau 20. Mar 2010 17:04
Selt, má eyða
Pósturaf goatboy » Mán 15. Jún 2015 18:06
Chipset GeForce GTX 660
PCB Form ATX
Core Clock Base clock: 1033 MHz
Boost clock: 1098 MHz
Memory Clock 6008 MHz
Process Technology 28 nm
Memory Size 2048 MB
Memory Bus 192 bit
Card Bus PCI-E 3.0
Memory Type GDDR5
DirectX 11.2
OpenGL 4.4
I/O
Dual-link DVI-I*1 DVI-D*1 DisplayPort*1 HDMI*1
Digital max resolution 4096 X 2160(via a single HDMI connector or DisplayPort and not supported with two DVI connectors)
Analog max resolution 2048 x 1536
Multi-view 4
15.000 eða besta boð, er í kópavogi
Síðast breytt af goatboy á Sun 21. Jún 2015 15:50, breytt samtals 1 sinni.
goatboy
Póstar: 15
Re: [TS] Geforce 660 OC 2GB
Pósturaf goatboy » Fös 19. Jún 2015 10:12
