BenQ GL2760H
Axle Rose
Póstar: 9
Skráði sig: Sun 12. Apr 2015 11:12
BenQ GL2760H
Pósturaf Axle Rose » Sun 12. Apr 2015 11:26
Er að athuga hvort það sé einnhver áhugi á skjánum min sem
BenQ GL2760H
Screen Size 27"W
Aspect Ratio 16 : 9
Resolution (max.) 1920 x 1080
Pixel Pitch (mm) 0.311
Brightness ( typ.) 300nits
Native Contrast ( typ. ) 1000 : 1
DCR (Dynamic Contrast Ratio) (typ.) 12M : 1
Panel Type TN
Viewing Angle (L/R;U/D) (CR>=10) 170° / 160°
Response Time(Tr+Tf) typ. 2ms (GTG)
Display Colors 16.7 million
Color Gamut 72% NTSC
Input Connector D-sub / DVI / HDMI / Headphone jack
Power
Power Supply (90~264 AC) Built-in
Power Consumption (On mode) 29W
Power Consumption (Off mode) < 0.3W
Power Consumption (Base on Energy star ) 21W
Dimensions & Weight
CTN Dimensions ( H x W x D mm ) 490 x 715 x 132
Dimensions ( H x W x D mm ) 488 x 641 x 215
Dimensions with Wall Mount ( H x W x D mm ) 379.55 x 641 x 56.95
Net Weight (kg) 5.4 kg
Gross Weight (kg) 7.3 kg
Special Features
Flicker-free Technology Yes
Senseye® Senseye 3
Windows® 8 Compatible Yes
HDCP Yes
Colour Temperature Reddish / Normal / Bluish / User mode
OSD Language 17 languages
VESA Wall Mounting 100 x 100 mm
Tilt ( down / up ) -5° / 20°
Dynamic Power Saving (DPS) Yes
K Locker Yes
Included Accessories
Signal Cable VGA
