seldur Airport Extreme Time Capsule 1 TB (A1254)
lollipop0
Póstar: 1148
Skráði sig: Lau 18. Jún 2011 13:46
Pósturaf lollipop0 » Sun 29. Jún 2014 13:15
Airport Extreme Time Capsule 1TB A1254
Security
Wi-Fi Protected Access™ (WPA/WPA2)
Wireless security (WEP) configurable for 40-bit and 128-bit encryption
MAC address filtering
NAT firewall
Support for RADIUS authentication
802.1X, PEAP, LEAP, TTLS, TLS, FAST
Time-based access control
Electrical
Line voltage: 100-240V AC
Frequency: 50Hz to 60Hz, single phase
Maximum continuous power: 30W
Agency approvals
FCC Part 15 Class B, Canada RSS-210, EN 300-328, EN 301-489, EN 301 893, ARIB STD-T66, RCR STD-T33, AS/NZS 4268: 2003, UL 60950, CSA-C22.2 No. 60950
Storage
1TB 7200-rpm Serial ATA server-grade hard disk drive
Interfaces
One Gigabit Ethernet WAN port for connecting a DSL or cable modem
Three Gigabit Ethernet LAN ports for connecting computers or network devices
USB port for connecting a USB printer or USB external hard drive
802.11n wireless
Wireless protocols
Draft 802.11n
802.11a/b/g
Compatibility
Interoperable with Wi-Fi Certified 802.11a, 802.11b, and 802.11g and 802.11n draft 2.0 Mac computers, Windows-based PCs, and other Wi-Fi devices
NAT, DHCP, PPPoE, VPN Passthrough (IPSec, PPTP, and L2TP), DNS Proxy, SNMP, IPv6 (6to4 and manual tunnels)
Frequency bands
2.4GHz or 5GHz
Specs
http://support.apple.com/kb/SP9
Verðhugmynd: 12.000kr
Síðast breytt af lollipop0 á Mán 07. Júl 2014 18:26, breytt samtals 1 sinni.
MacBook Pro 14" M1-Pro | Surface Duo 256GB | PS5 Disk | Sony Xperia IV
lollipop0
Póstar: 1148
Re: TS Airport Extreme Time Capsule 1 TB (A1254)
Pósturaf lollipop0 » Mán 30. Jún 2014 20:13
icemoto
Póstar: 14
Skráði sig: Fim 03. Maí 2012 01:39
Pósturaf icemoto » Mið 02. Júl 2014 11:18
Búinn að senda þér skilaboð
lollipop0
Póstar: 1148
Pósturaf lollipop0 » Sun 06. Júl 2014 15:39
lollipop0
Póstar: 1148
Re: seldur Airport Extreme Time Capsule 1 TB (A1254)
Pósturaf lollipop0 » Mán 07. Júl 2014 18:26
seldur
