SELT -17'' HP LCD tölvuskjár til sölu - SELT
silentkill
Póstar: 235
Skráði sig: Mán 16. Maí 2011 21:23
Pósturaf silentkill » Sun 18. Des 2011 14:47
er með vel með farinn 17'' HP skjá til sölu á 5.000 kr - SELDUR !
Mynd: http://www.akiele.com/lcd/hp/081125/l17 ... -L1706.JPG
upplýsingar um skjáinn ...
Product FeaturesFeatures
Type Thin-Film Transistor (TFT)
Size / Viewable Image Size (diagonal) 17.0 in (43.2 cm) maximum viewable
Native Resolution 1280 x 1024 @ 60 Hz
Signal Input 15-pin D-sub (analog VGA)
Horizontal Viewing Angle 140 degrees
Vertical Viewing Angle 130 degrees
Cabinet Colors Carbon/Silver
Image Quality
Brightness (typical) 300 nits (cd/m2)
Contrast Ratio (typical) 500:1 (typical)
Pixel Pitch 0.264 mm
Horizontal Frequency Range 30 to 83 kHz
Vertical Frequency Range 56 to 76 Hz
Ease of Use
User Programmable Modes 10
Plug and Play Yes
On-Screen Controls Image Control (auto, horizontal, vertical), Positioning (vertical and horizontal), Color Temperature (6500k, 9300k, Custom), Brightness, Contrast, Clock, Clock Phase, Monitor Management (power saver, sleep), Factory Reset
Language Selection Yes
Asset Control Yes
Resolution
1280 x 1024 60 Hz and 75 Hz
1024 x 768 60 Hz, 70 Hz, and 75 Hz
800 x 600 60 Hz, 72 Hz, and 75 Hz
720 x 400 70 Hz
640 x 480 60 Hz, 72 Hz, and 75 Hz
Ergonomic Features
Anti-Glare/Anti-Static Yes/Yes
Tilt/Swivel Yes/No
Tilt Angle -5 degrees to +30 degrees
Approvals / Certifications
MPR-II Compliant Yes
ISO 9241-3,7,8 VDT guidelines, ISO 13406-2 pixel defect guidelines Yes
Energy Star Compliant Yes
FCC Approval Yes
TCO '99 Certified Yes
UL Approval Yes
Hardware Features
Sync Input TTL separate synch
Dimensions without stand (HxWxD) 39.5 x 37.5 x 20.3 cm (15.6 x 14.8 x 8.0 in)
Weight unpacked 33.0 x 37.5 x 6.4 cm (13.0 x 14.8 x 2.5 in)
Weight packaged 4.6 kg (10.1 lb)
Accessories 6.1 kg (13.4 lb)
Síðast breytt af silentkill á Mið 28. Des 2011 20:35, breytt samtals 1 sinni.
silentkill
Póstar: 235
Re: 17'' HP LCD tölvuskjár til sölu
Pósturaf silentkill » Þri 20. Des 2011 17:17
tt
silentkill
Póstar: 235
Pósturaf silentkill » Mið 21. Des 2011 20:00
tt
binnzo
Póstar: 1
Skráði sig: Sun 10. Maí 2009 10:49
Pósturaf binnzo » Fim 22. Des 2011 14:01
Getur þú sett hann í póst ef ég kaupi hann af þér? Er fyrir norðan.
silentkill
Póstar: 235
Pósturaf silentkill » Fim 22. Des 2011 14:23
já ég get það en myndi vilja fá greitt áður en ég myndi senda skjáinn.
silentkill
Póstar: 235
Pósturaf silentkill » Lau 24. Des 2011 11:25
tt
silentkill
Póstar: 235
Pósturaf silentkill » Mán 26. Des 2011 13:56
tt
silentkill
Póstar: 235
Pósturaf silentkill » Þri 27. Des 2011 11:35
tt
silentkill
Póstar: 235
Pósturaf silentkill » Mið 28. Des 2011 11:46
tt
Flinkur
Póstar: 68
Skráði sig: Mán 01. Ágú 2011 11:37
Pósturaf Flinkur » Mið 28. Des 2011 12:02
býð 3500 kr :oops:
“I’ve wiped the file? … I’ve wiped all the files? … I wiped the internet? … I don’t even have a modem!”
silentkill
Póstar: 235
Pósturaf silentkill » Mið 28. Des 2011 12:37
Flinkur skrifaði:býð 3500 kr :oops:
nei þakka þér fyrir, 5.000 kr slétt ekkert prútt!
nellyx
Póstar: 3
Skráði sig: Fim 02. Feb 2012 22:59
Re: SELT -17'' HP LCD tölvuskjár til sölu - SELT
Pósturaf nellyx » Fim 02. Feb 2012 23:16
hi er hun til senda mer sms i 7727716 :japsmile
nellyx
Póstar: 3
Pósturaf nellyx » Fim 02. Feb 2012 23:23
eg borga 5000 :happy
silentkill
Póstar: 235
Pósturaf silentkill » Lau 11. Feb 2012 00:21
tt
