6Gb DDR3 GSkill Ripjaw 2000Mhz - CL9 / 1600Mhz - CL7
muszilla
Póstar: 34
Skráði sig: Lau 01. Okt 2011 20:27
Pósturaf muszilla » Lau 01. Okt 2011 20:42
6GB G.Skill DDR3 PC3-16000 2000Mhz Ripjaw + Turbulence Fan Series (9-9-9-24) Triple Channel kit
14.000 kr
** P.s. ég er að selja þetta fyrir kærastann minn og mér fannst bara rétt að leyfa því sem hann skrifaði að vera á ensku svo að ég segði nú ekki eithvað vitlaust :D
They work at the same voltage with 8-9-8-24-2N latency settings on 2000Mhz but if you want to use on 1600Mhz, according to Gskill forums, you can use at 7-7-7-21 or even 6-7-6-18 timings. Those rams are really fast especially for gamers and hardcore users. They support XMP settings, but with some motherboards you may need to set settings manually. I am selling just due to I am shifting to an AMD system soon. I did not even use additional fan once so it is brand new and I will be giving everything in its original box.
6GB DDR3 2000MHz Ripjaw Series Triple Channel kit from G.Skill, supplied with Turbulence cooling fan. Three matched 2GB PC3-16000 memory modules, rated CL9 (9-9-9-24), 1.6V, 240 pins. Backed by lifetime manufacturer's warranty.
Designed for the Intel X58 chipset and pre-tested in a wide range of ASUS, MSI, and DFI motherboards. Also suitable for other motherboards designed for triple channel memory kits.
Full memory timings of 9-9-9-24-2N
6GB memory kit = 3x 2GB memory modules
** Reference feedback from users >>> http://www.newegg.com/Product/Product.a ... 6820231411
** Extra Photos >>> http://www.newegg.com/Product/ImageGall ... L9T-6GBRHD
muszilla
Póstar: 34
Re: 6Gb DDR3 GSkill Ripjaw 2000Mhz - CL9 / 1600Mhz - CL7
Pósturaf muszilla » Sun 02. Okt 2011 13:06
upp...
muszilla
Póstar: 34
Pósturaf muszilla » Sun 02. Okt 2011 17:37
engin skipti takk :)
muszilla
Póstar: 34
Pósturaf muszilla » Mán 03. Okt 2011 10:55
upp :)
muszilla
Póstar: 34
Pósturaf muszilla » Þri 04. Okt 2011 11:41
123...
muszilla
Póstar: 34
Pósturaf muszilla » Fim 06. Okt 2011 10:34
upp :)
muszilla
Póstar: 34
Pósturaf muszilla » Sun 09. Okt 2011 04:17
123... :)
muszilla
Póstar: 34
Pósturaf muszilla » Mán 10. Okt 2011 14:06
upp :)
muszilla
Póstar: 34
Pósturaf muszilla » Mið 12. Okt 2011 12:47
upp :)
muszilla
Póstar: 34
Pósturaf muszilla » Fim 13. Okt 2011 21:41
upp :)
Halldór
Póstar: 331
Skráði sig: Lau 30. Apr 2011 22:27
Pósturaf Halldór » Fim 13. Okt 2011 22:05
Hvað eru þessar viftur háværar?
i7 2600k | Corsair H80 með 2x Gentle Typhoon AP-15 1850RPM | Gigabyte Z68X-UD7-B3 | G.Skill sniper 2x4GB @ 1600 MHz | Sapphire Radeon 6950 Flex edition | Corsair 750D | SSD: OCZ Vertex 3 MAX IOPS 120 GB| 1TB Seagate Barracuda | Corsair AX1200 | W7 x64
muszilla
Póstar: 34
Pósturaf muszilla » Lau 15. Okt 2011 23:37
upp :)
muszilla
Póstar: 34
Pósturaf muszilla » Sun 16. Okt 2011 17:29
upp :D
muszilla
Póstar: 34
Pósturaf muszilla » Mán 17. Okt 2011 14:51
upp :)
muszilla
Póstar: 34
Pósturaf muszilla » Mið 19. Okt 2011 11:22
upp :)
niCky-
Póstar: 729
Pósturaf niCky- » Mið 19. Okt 2011 12:07
býð 10k um mánaðarmótin
muszilla
Póstar: 34
Pósturaf muszilla » Fim 20. Okt 2011 11:05
upp :)
muszilla
Póstar: 34
Pósturaf muszilla » Fös 21. Okt 2011 14:56
upp :)
spanktv
Póstar: 52
Skráði sig: Fim 11. Feb 2010 02:17
Pósturaf spanktv » Lau 22. Okt 2011 15:54
Kisildalur.is - Karfan mín skrifaði:
Verðið sem þú villt fá fyrir þitt er of hátt. Prófaðu 7.000 - 9.000.
cure
Póstar: 886
Pósturaf cure » Lau 22. Okt 2011 15:56
Reyndar 2000Mhz vs 1600Mhz
MatroX
Bannaður
Póstar: 3540
Pósturaf MatroX » Lau 22. Okt 2011 16:11
cure82 skrifaði:Reyndar 2000Mhz vs 1600Mhz
og 2x4gb vs 3x2gb.
þetta verð sem hún er með er flott
spanktv
Póstar: 52
Pósturaf spanktv » Lau 22. Okt 2011 16:12
Reyndar 6.gb vs 8 gb
MatroX
Bannaður
Póstar: 3540
Pósturaf MatroX » Lau 22. Okt 2011 16:15
spanktv skrifaði:Reyndar 6.gb vs 8 gb
skiptir engu máli.
þetta er triple channel minni vs dual channel. sitthvor hlutirinn
Minuz1
Póstar: 1276
Pósturaf Minuz1 » Lau 22. Okt 2011 18:26
MatroX skrifaði:
skiptir engu máli.
En skiptir það einhverju máli?
Ég hef ekki séð nein rosaleg performance mun á milli single channel og dual channel, efast um að það sé eitthvað annað með dual vs triple.
Er þetta ekki bara sölutrikk?
Prags9
Póstar: 137
Skráði sig: Fim 09. Ágú 2007 18:58
Pósturaf Prags9 » Lau 22. Okt 2011 18:36
passar þetta eithvad vel med þessu http://www.corsair.com/memory-by-produc ... 00c8d.html
