ViewSonic 24" 16:9 1080p VX2433wm
http://www.viewsonic.com/products/deskt ... 2433wm.htm
Óska eftir Tilboði!
Size 60 cm (23.6") wide Color TFT Active Matrix LCD 16:9 aspect ratio
Display Area 20.5 (in) × 11.5 (in) / 521 (mm) × 293 (mm)
Optimum Resolution 1920×1080 WUXGA
Contrast Ratio 1000:1 (typ), 20,000:1 dynamic
Brightness 300 cd/m² (typ.)
Viewing Angles 170° (H), 160° (V) at 5:1 c/r
Response Time 2ms (G to G) ; 5ms (on/off)
Pixel Pitch 0.2715mm (H) × 0.2715mm (V)
Panel Surface Anti-Glare, Hard coating (3H)
Color Support 16.7M (6-bits + Hi FRC)
VIDEO INPUT
Analog RGB Analog (75 ohms, 0.7 / 1.0 Vp-p)
Digital DVI-D (TMDS, 100ohms, with HDCP), HDMI 1.3
Sync Separate Sync / Composite Sync / SOG
Frequency Fh: 24-83kHz, Fv: 50-76Hz
COMPATIBILITY
PC VGA up to 1920×1080 non-interlaced
Mac® Power Mac up to 1920x1080
CONNECTOR
Analog 15 pin mini D-sub × 1
Digital DVI-D (with HDCP) / HDMI
Audio 3.5 mm Audio in / 3.5 mm Audio out
Power 3-pin AC plug (CEE22)
AUDIO
Speakers 2 × 2 watt with SRS WOW sound*
POWER
Voltage AC 100-240V (Universal); 50/60Hz (Switch)
Consumption 45 (typ.)
Eco Mode optimize 37W (typ.) / conserve 30W (typ.)
Save Mode (W) ≦2W
ERGONOMICS
Tilt 20° ~ -5°
CONTROLS
Basic [1], [2], Power, Down, Up
On View (PC mode) Auto image adjust, contrast/brightness, input select (D-sUB, DVI, HDMI PC, HDMI AV), audio adjust (volume, mute), color adjust (sRGB, 9300K, 7500K, 6500K, 5000K, user color [RGB]), information, manual image adjust (H/V position, horizontal size, fine tune, sharpness, dynamic contrast, response time, aspect ratio, display mode, ECO mode), setup menu (language, resolution notice, OSD position, OSD timeout, OSD background, sleep), memory recall
OPERATING CONDITIONS
Temperature 0 - 40°C (32 - 104°F)
Humidity 20-90% (non-condensing)
DIMENSIONS (WxHxD)
Physical With Stand 22.5" × 16.5" × 9.1" (572mm × 418mm × 231mm)
Physical Without Stand 22.5" × 14.1" × 2.5" (572mm × 359mm × 62.3mm)
WEIGHT
Net 11.1 lbs (5.04 kg)
Gross 15.5 lbs (7.05 kg)
REGULATIONS
UL, CUL, FCC-B (ICES), CB, CE, CES-003B, VCCI, Nemko ERGO (MPR II, ISO 13406-2), TUV-S, NOM, GOST-R, HYGIENIC (20 copies), CCC, BSMI, PSB, C-TICK, KTL/MIC, SASO, WEEE, RoHS, Ukraine
WALL MOUNT
VESA 100mm × 100mm
RECYCLE/DISPOSAL
The lamp in this product contains mercury. Please dispose of in accordance with local, state or federal laws.
The VX2433wm widescreen LCD is ideal for gamers, HD enthusiasts, and graphics professionals.
* Full HD 1080p performance for unsurpassed HD viewing
* Ultra-fast 2ms video response for crystal-clear images
* Impressive 20,000:1 dynamic contrast ratio provides greater detail and definition
* Multiple inputs including HDMI with HDCP give you extensive connectivity options for high-def data and entertainment
* Integrated SRS WOW HD speakers for amazing sound
* Aspect ratio adjustment ensures your images are never distorted regardless of signal source
* Eco-mode automatically reduces power consumption and can extend backlight life.
Features
100mm x 100mm VESA® wall mount compatible
Provides darker black levels and better overall front-of-screen performance.
ClearMotiv® 2ms video response time
Ultra-fast 2ms video response enables digital HD broadcast-quality video.
ECO-mode
Environmentally-friendly ECO-mode reduces power consumption and extends backlight life.
OptiSync® digital/analog inputs expand your connectivity
Multiple input technology supports both digital (DVI, HDMI) and analog (VGA) signals for ultimate compatibility and configuration flexibility.
Stereo speakers with SRS WOW HD for amazing sound
Stylish slim-bezel design with high-gloss, piano-black finish
Takk fyrir..
