775 - móðurborð til sölu (MSI G41TM-E43)
Aimar
Póstar: 1421
Skráði sig: Mið 01. Sep 2004 09:43
Staðsetning: 201
Pósturaf Aimar » Fös 15. Jan 2010 18:17
Ég keypti vitlaust móðurborð og því þarf ég að losa mig við þetta.
Keypti
Fullt verð. 13.950.-
Fer á 10kall. tel það mjög sanngjarnt fyrir borð sem hefur aldrei verið notað. Auðvitað hægt að láta prenta út nótu fyrir þann sem kaupir það.
Sendið mér pm.
MSI G41TM-E43
http://www.att.is/product_info.php?cPath=41_25_161&products_id=4895
Spec.
Supports Intel® Core 2 Quad/Core 2 Duo based processors in LGA775 package.
• Supports Intel® Yorkfield, Wolfdale in the LGA775 package.
• Supports Intel® next generation 45nm multi-core processors
• Supports FSB 1333/1066/800 MHz.
• Supports VRD 11.1 standard.
• Supports FMB 05a@95W
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® G41 Chipset
- Supports FSB 800/1066/1333 MHz.
- Supports DirectX10.
• Intel® ICH7 Chipset
- Hi-Speed USB (USB2.0) controller, 480Mb/sec, up to 8 ports.
- 4 SATAII ports with transfer rate up to 3Gb/s.
- 1 channel Ultra ATA 100 bus master IDE controller.
- PCI Master v2.3, I/O APIC.
Main Memory
• Supports two unbuffered DIMM of 1.8 Volt DDR2 667/800 SDRAM, 8GB Max
Slots
• One PCI Express x16 slot (PCI Express Bus SPEC V1.0 compliant).
• One PCI Express x1 slot.
• Two 32-bit v2.3 master PCI bus slots.
- Support 3.3v/5v PCI bus interface.
On-Board IDE/SATA
• One Ultra DMA 66/100 IDE controller integrated in Intel® ICH7
- Supports PIO, Bus Master operation modes.
- Can connect up to two Ultra ATA drives.
• SATAII controller integrated in ICH7 chipset
- Up to 3Gb/s transfer speed.
- Supports four SATAII ports by ICH7
Audio
• Chipset integrated by Realtek® ALC888S / ALC889 / ALC885
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
- Meet Microsoft Vista Premium spec
LAN
• Supports PCI Express LAN 10/100/1000 Fast Ethernet by Realtek 8111DL
Internal I/O Connectors
- ATX 24-Pin power connector
- 4-pin ATX 12V power connector
- CPU x1/ System x2 FAN connectors
- CD-in connector
- Front panel audio connector
- Front panel connector
- 1 x chasis intrusion connector
- 2 x USB 2.0 connectors
- 1 x Floppy disk drive connector
- 4 x Serial ATAII connectors
- 1 x ATA100 connector
- 1 x SPDIF-Out connector
- Clear CMOS Jumper
- 1 x OC Switch
- 1 x Serial port connector
- 1 x TPM module connector (optional)
MSI Reminds You...
• The floppy disk cable will be optional.
Back Panel I/O Ports
- 1 x PS/2 keyboard
- 1 x PS/2 mouse
- 1 x 6 in 1 audio jack
- 4 x USB 2.0 ports
- 1 x RJ45 LAN jack
- 1 x Graphics Card port
- 1 x DVI-D port
- 1 x HDMI port
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 24.4cm(L) x 20.5cm(W) mATX Form Factor
GPU: AMD Radeon™ RX 7900 XT - GA z590 gaming X - Intel Core i7 11700k - Corsair Rm750x - Noctua-U12S - iCUE 465X RGB Mid-Tower- AORUS RGB Memory DDR4 16GB x4 3733MHz - Samsung 970 EVO 1TB M.2 2280 SSD - Win 10 Pro 64bit - ASUS ROG Swift Curved PG348Q @ 100mhz
