[Casemod] Fractal Design Define S Nano "Hot Rod Edition"
jojoharalds
Póstar: 1619
Staðsetning: Cicada - 3301
Pósturaf jojoharalds » Fös 07. Okt 2016 22:37
Sælir Vaktarar
Var að klára nýjasta moddið mitt og er ferlið hér,
The colour Theme ---
Hot rod Red on the outside and some components will be red aswell,
white interior
And some chrome here and there
also will have some black in there.
ToDo:
Test loop, [DONE]
get adapters that are needed, [DONE]
test run on the hardware, [DONE]
Dissassemble the whole case,[DONE]
Paint each panel of the case,[DONE]
reassemble the case,[DONE]
Custom Sleeve the Psu cables [DONE]
LEAKTEST [DONE]
Final Photoshoot [DONE]
Components:
CASE: Fractal Define Nano S
Fans: Fractal Design Dynamic X2 GP-12
Aquacomputer Aquaero 6 with remote
Mainboard: ASrock FM2A88X-ITX
CPU : AMD 7700K @ 4.6 ghz
RAM:8Gb Kingston HyperX Predator Beast @ 2133 mhz
GPU: MSI - 970
PSU:Fractal Edison M 650 Watts Gold Certified
SSD: 120Gb Samsung EVO
HDD: 4Tb Wester Digital Red. (Depatched)
Watercooling:
Pump:Aquacomputer aquastream ultimate
Rad 1:Alphacool
Rad 2:Alphacool
Res: XSPC ION Reservoir
CPU:EK Supremacy
GPU:EK - 970 Block and an EK backplate
Fittings :Aplhacool rigid fittings
Enjoy the Buildlog.
The Powersupply from Fractal
Test fitting some hardware and planing the loop.
Ram clearence is an issue we all know about.
And well it is happening hhere as well,
It is something to expect when trying to go all small on a computer build with watercooling.
But there are ways of fixing this ☺
MyndMyndMynd
jojoharalds
Póstar: 1619
Re: [Casemod] Fractal Design Define S Nano "Hot Rod Edition"
Pósturaf jojoharalds » Fös 07. Okt 2016 22:39
Drain and fill port system in the making.
Keep in mind this is only a test fit
The final loop will be done with other piping and all the fittings will be chrome.
MyndMyndMyndMyndMyndMynd
I think this part of the loop will look great once it is in its finao stages
What do you think?
MyndMyndMyndMyndMyndMyndMyndMyndMynd
jojoharalds
Póstar: 1619
I think this turned out alright ,
Now on to the next part :)
MyndMyndMyndMynd
Front Panel progressing nicely :)
Going for that Ford Model A look ,still lots of work ahead.
and finally it continues...
First order of parts have arrived...
I sure love me some fittings
together with some nickel plated tubing and Alphacool flowsensor (which in my opinion is a gorgeos Design)
jojoharalds
Póstar: 1619
Pósturaf jojoharalds » Fös 07. Okt 2016 22:40
First nickel plated pipes are in place
we i am able to close everytging in the back.
and the front end (Grill) is in progress aswell.
Preparing the Case for paint MyndMyndMynd
jojoharalds
Póstar: 1619
Pósturaf jojoharalds » Fös 07. Okt 2016 22:41
Got an extra set of fans today.
and started painting them.
MyndMyndMyndMynd
jojoharalds
Póstar: 1619
Pósturaf jojoharalds » Fös 07. Okt 2016 22:42
everything was sanded and primer applied after applying primer i wet sanded everyrhing and cleaned it up.
Now it was time to add the colour.MyndMyndMyndMyndMynd
A few Spraycans and 30 Rivets later :)
I think the result is looking alright :)
-- Define Nano S Hot Rod Red --
jojoharalds
Póstar: 1619
Pósturaf jojoharalds » Fös 07. Okt 2016 22:43
The tubing is comimg along nicely
Now it is time to sleeve this Powersupply up.
and make a few colour changes to it MyndMyndMyndMyndMyndMynd
After A tonn of Sandpaper i finally got the colour of the Psu
and then polished.
So that i am able to see the Gpu´s reflection
Now i just have to wait for some Sleeving material,so that i can dress them cables :)
MyndMyndMynd
Power switch added MyndMynd
jojoharalds
Póstar: 1619
Pósturaf jojoharalds » Fös 07. Okt 2016 22:45
Front panel almost done
Dressing up some cables
the rest will be finished once more supplys will arrive MyndMyndMynd
Fractal Design "Hot Rod Edition" FINISHED!!
Here is the final Photoshot of the Build,
http://imgur.com/a/1gj14
Myro
Póstar: 75
Skráði sig: Fim 27. Okt 2011 18:45
Pósturaf Myro » Lau 08. Okt 2016 09:47
Þessi er alveg svakalega töff. Á hvaða síðu ertu að pósta build log?
linenoise
Póstar: 411
Skráði sig: Þri 12. Júl 2011 16:35
Pósturaf linenoise » Lau 08. Okt 2016 13:05
Holy hotrod! Þetta er alveg á nýju leveli.
I-JohnMatrix-I
Póstar: 1020
Skráði sig: Fös 05. Apr 2013 19:01
Staðsetning: Reykjanesbær
Pósturaf I-JohnMatrix-I » Lau 08. Okt 2016 14:23
Virkilega flott ! Ég verð alltaf spenntur þegar ég sé nýjan mod þráð frá þér, það er svo gaman að skoða yfir þetta og sjá allt ferlið.
jojoharalds
Póstar: 1619
Pósturaf jojoharalds » Lau 08. Okt 2016 14:57
I-JohnMatrix-I skrifaði:Virkilega flott ! Ég verð alltaf spenntur þegar ég sé nýjan mod þráð frá þér, það er svo gaman að skoða yfir þetta og sjá allt ferlið.
Takk :)
